Mk3 Fiesta Track/hillclimb Car
My fiesta began its life as a trade in i picked up cheap.. the three door 1.1L
it was my daily run around i soon had avo lowering springs on it. The steels wheels needed to go
so i replaced them with escort 5 spokes in white which gave it that rallyesc look. A pair of OMP fixed back
buckets went in then poor little 1100 gave up and through a rod through the block.....
That was it then i had a decent 3door shell and no engine so me and my friend decided to start up our garage anticks again and build a
hillclimb/road rally car.
but no ordinary fiesta mk3 track car oh no
first thing was strip it to shell then we went in search of parts to turn our new found project in to something different we sourced
a sierra 2.0l 8v with the ajoining gearbox it was then we decided to go rwd.
the parts we salvaged from the sierra
2.0l 8v efi
full wiring loom
gear box
ignition barrel key
ecu
front struts
front subframe
front engine mounts
front brake setup and hubs
the rear end of the car we wanted to create something a tad different again so we turned to another manufacturer (which some of you may not agree with but hay)
we removed the rear running gear from a subaru impreza
diff
rear subframe
drive shafts
trailing arms
rear brake drums
but soon to be swapped for discs
yet we still had a shell with not a lot going on on it ........
so we invested in a full bolt in OMP roll cage
and basically thats it
i will post pictures of how far we have got soon
please let me know what you think
and if anyone has any ideas or usefull input then i will be very greatful
cheers
Sounds differet - keen to see pictures!
here are some pics of it so far engine mounted and the front subframe and suspension all in and together. The cage is also fitted and everything is coming together well.22550_1399598949502_1218122219_31216021_406750_n.jpg
