MK5 Front Fog Lights not working
Hi Guys,
I might be being silly here or asking something that's already been covered, but my front fog lights do not seem to be working on my mk5 estate. I have the X pack with the LED headlights. When I press the button for the front fog lights I get the symbol on the dash board that they are on but they do not actually come on. I have checked the lamps and they are fine. I know on the older models the front and rears are connected on the same fuse, i'm not sure if it's the same for the mk5's? if it is then the rears do work so that would show the fuse is fine?
Any help would be very much appreciated!
TIA
Check fuses first by swapping them with eligible counterparts. Also test bulbs, actually connect them to 12v see if they illuminate. If all checks out start checking the wiring with a basic multimeter, start from the relay in the fuse box and work toward the bulbs.
Rossco
