Mondeo tdci mk3 temp issue
Hi all
my mondeo has always been poor on fuel based on my last heavier estate always returned 56mpg doing short journeys always cold on 30mph roads
i now have a low mileage 70k hatchback same age that I religiously drive at 57mph 80 miles a day to work and back and it returns 47mpg!
ive noticed that the temp gauge is all over the place and never really gets warm. I just took it out and hammered it for 2-3 miles at 50mph in 3rd gear and once the temp gauge hit the middle I measured the temp with an infra red gun.
rad hose from rad to stat was 75
post stat to heater matrix was 55
oil stat hose was 75
header tank was 34
rad was 65
then I drove home in 4/5th around 30mph and when I got home temp gauge was back to the zero on 60
measured same things again
rad hose from rad to stay was 73
post stat to heater matrix was 65
oil stat hose was 65
header tank 32
rad 66
and to make it easier to read
75-73
55-65
75-65
34-32
65-66
the car gauge is always on cold on the motorway, the minute you hammer it or reach an incline it starts to creep up but soon goes straight back down again
ac is never on.
have changed the oil stat today and no difference
the heater kicks out really hot air
what the hell is going on?
Temp sender?
33 minutes ago, Russ 6334 said:
Possibly but where is it? And why would it fluctuate like this when the physical temps aren’t?
Running cold on the motorway and constant low temperatures. This sounds like a coolant thermostat stuck open to me. Heating probably will be warm as the hose usually comes straight out the engine to the matrix.
I have a mk3 petrol and I know the thermostats on them are a common problem but not sure if the diesels are the same.
