Engine Warning Light - New Battery?
This morning, I had to have a new battery fitted, as the old one had died. Later today, the solid engine warning light came on and is still there this evening. The card has only recently had a full service. Is this a coincidence? Could the loss of battery power explain the warning? Various other settings were lost, such as radio code, clock date/time, window buttons, etc.
Please may I get your advice?
Thanks, Jonathan
Mondeo TDCI 1997cc diesel 58 plate
I would really appreciate some advice please
You'll need to have the fault codes checked if you've got a constant engine malfunction light.
Thanks Tom
usually cheaper to get your own OBD fault code reader than it is to pay someone else to do it.
I have USB one from here  https://tunnelrat-electronics.fwscart.com/
which I use with my laptop, having downloaded free software (Forscan) here:  https://tunnelrat-electronics.fwscart.com/page/help
If you buy one somewhere else be sure to get a 'modified' one which has a switch added so you can access more stuff on a Ford.
This seller has been recomended many times on the Ford owners club forums and is where I got mine from
