LED rear lights - MK8
Does anyone have the part numbers for the new model (2017>) rear LED lights?
They come in 2 separate components for each side - inner and outer.
The outer part numbers are:
2255984 - Right Hand
2255986 - Left Hand
they’re quite pricy though, just the outer parts alone are £150 each.
Struggling to find the p/n for the inner components however based on the part numbers for the outer components I would maybe try guessing the numbers as the same as the outers but the end digits being xxxxx85 and probably xxxxx83 but that’s only me taking a shot 😛
are you thinking of doing any changes?
Keep looking on the bay for used lights but sellers don;t know if they're led or not, sometimes part numbers are there but i wasn't sure what they were
Wanting to upgrade from the halogen ones 🙂
Do you know if any wiring work is needed to convert?
I've seen posts saying they're plug and play
Fingers crossed then, good luck with it, definitely a worthy upgrade if it’s just plug and play!
  • 11 months later...
Apologies for resurrecting a pretty old post! Was just wondering if you had any luck with this?
I have exactly the same model of Fiesta and want to do this upgrade myself.
I got these plug and play really bright white..
  • 8 months later...
Do these units come brand new with led bulbs in them?
H1BB13404BH 2255984
https://www.evnewsj.com/index.php?main_page=product_info&products_id=414280
This is the LED product but I am also finding those 2 part numbers
H1BB13404BH
And
2255984
Showing as non led on some listing. So confusing. Why can Ford not just have one number for each thing
If you give your Reg No to ford they will give you the correct part.
H1BB13404BH is definitely the correct part number.
This seems too good to be true. 75 quid for genuine brand new part. It even states with LED.
I have seen a few companies in Germany selling brand new for 190 pound. I guess will be 200 minimum in the UK from Ford.
I only need one. Looks like 150 for each in the UK.
Have you sourced a lens yet and if so how much and where did you get it from.
