DTC P1889
Hello all,
My beloved Focus ST diesel suddenly went into limp mode. I scanned with Forscan and found the following code -
Code: P1889 - Oil Pressure Pump Performance
I have done some searching on this but not been able to find much info on what the issue might be?
Could be the oil pressure switch or the oil pressure control solenoid at fault. The dw10c engine has variable pressure oil pump.
Wow - thanks for the quick response. Time to roll the sleeves up and get stuck in.
Cheers
Mark
There both just above the oil filter.
Thanks again.
I will let you know how I get on 🙂
  • 5 years later...
How did you get on to fix that P1889 - Differential Oil Pressure Pump Performance ? Thank you
You're too early. The OP hasn't had time to get back to us all just yet 🤣
Threads quite often come to an abrupt halt without finding out the outcome.
This is not what the forum is all about. We are expected to share the experiences/knowledge to help others.
I take OP is not on this anymore.
That would be a "no"
