Footwell full off water /coolant
Hi there I’m constantly topping up my coolant now my driver side foot well is full of water/coolant any ideas
heater matrix may be leaking :sad:
You might be lucky in it just being the pipe connection to the heater matrix, very common on early mk3s and they changed the design on later ones to a 'one piece' design so no chance of leaks there.  Look above the pedals and the left hand side and you should see the silver pipes with a plastic connector there, at the rate its leaking you should see drips quickly.
If it's not that then it'll be the matrix itself which is a huge job...over £1000 at a main dealer!
