side lights
Focus titanium mk2 1.6.tdci..I have a problem with my side light BOTH front are not working  i have checked 1 bulb and it was ok ..i have checked and there is no power..the rear lights are on the dash indicator light is on and all the other electrics and lights seem fine..could it be a fuse as i was under the impression the fuses covered left and right not front and back ..
Possible that both both have blown
both bulbs are fine ..no supply to either bulb connector ..earth is fine, fuses are fine..circuits are split left and right at fuse box so as rears work that is not the issue ...
You need to check the connectors on the fusebox for corrosion. The front left and right sidelight circuit uses the same connector c96. If no corrosion you will need to check for 12 v at the wires coming out connector c96 to side lights. Pins 28 orange/green and pin35 orange /blue
