Engine Malfunction, Service Now & Error Codes
Hello All,
I have a 14 Plate Ford Fiesta Ecoboost 1l Petrol, that is in limp mode. I was driving one evening and it was fine, the next morning I woke up for work and the engine started up, but flashed up with the spanner symbol and notification of Engine Malfunction Service Now. It was serviced just 4 months ago came back fine no issues. I've taken it to a garage and they have got the following error codes:
P06A6 - Sensor referential voltage fault in circuit, P0558 - Brake Booster Pressure Sensor Signal Too High, P2135 - Throttle Valve/Pedal Faulty Signal, P1573 - Throttle Valve Signal Missing, P0106 - Air Pressure/Boost Pressure Sensor Faulty Signal, P0238 - Boost Pressure Sensor Signal Too High, P0234 - Boost Pressure intake Pipe Pressure Too High, P00CF - Boost Pressure Turbo Charger Faulty Signal.
The Garage wasn't sure what was wrong with it and suggested booking it in with a Ford Specialist, they are looking at the car on 16th, but didn't know if I could check anything before then?
Any help would be gratefully appreciated.
Thanks, Owen
Hi Owen , Sorry I'm unable to help but I too have recieved the spanner symbol with engine malfunction service now about 2 times however the car has never gone into Limp mode with me , What did the specialist say ?
