Do I need special tool to do wheel bearing 06 Focus TDCI?
Hi there,
The Haynes Manual says I need a special tool for the job but will a 23 piece set by someone like Sealy have what I need?
is it something I can do in my garage and will I need a bearing press?
Hi Colacharlie
If its the front bearing with ABS I would buy something like this, Should work out cheaper than having to  buy that Sealy kit and you will still need the use a press. Replaced one on my 06 Focus about a month ago.
https://www.ebay.co.uk/itm/FORD-FOCUS-MK2-2004-2012-FRONT-WHEEL-BEARING-HUB-KIT-WITH-ABS-BRAND-NEW/171096702483?hash=item27d6287e13:g:rygAAOSwlyJZbMSW:rk:1:pf:1&frcectupt=true
Edited by eddie eastwood
altered info
If you want it to last you need special tools. These are gen2 wheel bearings that require special clam shells to press in properly. I wouldn’t entertain anyone doing this job without.
