Ahmud Bholah
Please help.  has anybody come across ford galaxy 1.9 tdi gearbox problem. the reverse is fine. but reluctant to move initially as if starting to move on 2nd gear . probably drive on 4th gear at around 50-60 mph and revving at 3000 rpm which is high. as if not going into 5th gear. also all the gears selection on the dashboard are lit up, instead of pointing to drive or reverse/ neutral etc. tried disconnecting battery for a while, sprayed brake switch with wd40, added 250ml of transmission fluid. did not make a difference. checked the level by removing the small "allen" plug and allowed some fluid out -- the 250 i added; but fluid kept coming so i stopped. advice needed, Thank you
