Amazon music
Amazon music app anyone had any experience using it with sync3? Im thinking about using it.
Doesn't work.
Try Ford+Alexa, install on your phone then you get an Alexa tab on your audio source screen.
My car communicates with the wake up word and also via the voice button if vehicle noise picks up too far.
I have full Alexa operability.
Just make sure you open the app on your phone while in the car.
Sent from my SM-G965F (S9+)
Works great through Android Auto, don't know if it's supported on Apple Carplay too?
1 hour ago, Stoney871 said:
Doesn't work.
Thanks for that, i dont think ill bother seems a right faff cant even find ford alexa
It's no faff at all.
Install and set up the Ford+Alexa app, connect the phone by bluetooth and select the app on phone.
Ive tried to find it but it comes up as not available in your region.
2 minutes ago, Stoney871 said:
What region and which device?
Iphone 6s and uk
What sync version?
The app needs sync3 (version 2.2 and above) to function.
If you have sync2 or earlier you could buy a cheap echo dot (version 2 works well and available for about £25) and plug in via an aux cable.
You'd have to set the dot to run on a wifi hotspot which is a bit of a palaver tbh but once done will add full Alexa functionality.
Unfortunately Ford don't seem to have factored in linking a echo dot to the car's bluetooth.
I tried this with a spare echo dot, all working on mobile hotspot and powering up just fine but even though the car saw the bluetooth device it wouldn't connect.
The Ford+Alexa app works just fine for me now though.
I cant even get the app, the app store say not available in this country or region, as to sync its sync 3 version 3.3
7 minutes ago, Stoney871 said:
Thanks but it still takes me to the App store and the not available  in you country  msg
