Headlights
I've just bought a 2014 fiesta zetec s and when I turn the engine on the dipped headlights come on why is it doing this? Cheers
That's probably DRL's (daytime running lights).
They became a legal requirement on all vehicles designed after 2011.
https://en.m.wikipedia.org/wiki/Daytime_running_lamp
Either that or you have automatic lights turned on.
Same thoughts as above. Note also that some fiestas had daytime lights before ford started using newer headlamps with a line of leds at the bottom for the daytime lights
Is there anyway I can turn these off? They aren’t daytime running lights thanks
On lower trim levels Ford don't use LEDs but a bulb.
If you have front bulbs on but nothing at the rear, they're just non-LED DRLs, you won't be able to turn them off, they're a legal requirement
