Ford Fiesta 1.25 - Low Cylinder Pressures (all 4)
At loss here everyone. Changed engine oil on my step sons 2006 fiesta 1.25 Duratec. Since then its lost cylinder pressure’s apparently and running very rich. Tried all the usual stuff. Throttle body, map sensor, O2 lambda sensor. Will only idle if you create a vacuum leak by pulling the pipes off fuel vapour solenoid, which does work and fuel canister also checked. With live data from a diagnostic tool fuel trim is max.
Have you checked pressures with a compression tester or is that fault codes?
Did you use an engine flush or the wrong oil?
An awful lot of parts changed and not much information to go on
