DPF or DPS problem?
Hi.
My ford focus 2011 just starting showing the light with error P2002 particular filter below treshold. Just got it checked and cleaned the filter. The same day took the car back and it shows again the error. Send it back to the garage. They said it was the sensor. Changed the sensor and checked all the pipes even the EGR. All ok. A week later it shows another error P244A, differential pressure sensor. Send it today and now i am still waiting. I have done a lot of miles on the motorway to do the regeneration its way before cleaning the filter but nothing. Also after cleaning and changing the sensor a full reset of the system. Any idea what it might be?
Thanks.
Mers.
  • 11 months later...
On 6/27/2019 at 7:02 PM, Mers said:
Hi.
Thanks.
Mers.
Check the pressure hoses from the DPF to the differential pressure sensor, they tend to perish over time 🤞 eBay some silicone replacement hoses and new jubilee clips and replace them if the car is high mileage it'd be worth a try for less than £20, then just reset the codes through forscan and take the car for a run and hopefully that will be your cause.
