Ford Galaxy
Hello everyone
I currently own a ford galaxy 2.0tdi  59 plate with the peugeot engine with an automatic gearbox
I recently was driving and in 3rd gear and noticed from 3rd gear it would not go into 4th gear and there was a loss of power engine management light came on.
So after getting home I put the obd machine on and found one code p2236 turbo charger boost performance.
I have checked all pipes etc and nothing appears to be loose I took out he map sensor which had oil residue and I cleaned that with brake cleaner the EGR valve I replaced as it was blocked but I can't seem to pin point what is causing this low boost!
I have looked under the engine and when I move the turbo actuator it moves by hand but noticed on standstill when I rev the engine the actuator does not move in the slightest. The actuator has a vccum pipe with a multi plug attached on top.
Would appreciate any help in the slightest please thanks
