Cruise control/start stop/push start
Hi. I’ve recently had some work done to me 2011 focus 1.6 TDCI titanium and this work required the battery to be disconnected. Since then I have had no cruise control, start stop will not turn on and to start the engine I now have to hold the start button down rather than just press it like I used to. I looked into the other menu and it said that my battery was at 11.7. I know this is too low. If I leave my car running for a few hours will this bring the car back to normal functionality? Or is there an underlying issue that I need to get looked at
I wouldnt trust the on board voltage meter. Best get a multimeter over the positive and negative terminals for a proper reading. Ideally you want it to be just over 12.5v when the engine isnt running.
However if your battery is genuinely too low then your stop start wont work. What work did you have done?
To be honest with you I couldn’t tell you. I was driving a few weeks ago and the clutch suddenly stopped engaging. He is a family friend and qualified mechanic so he does us work with very little labour. We were trying to establish the problem without fitting a new clutch as the symptoms did not match any part of the clutch system failing. Anyways in the end he put a new clutch in and it worked but he had to disconnect the battery a few times for some other things he checked over for me (again I couldn’t tell you what). Would it be a result of any fault codes? The OBD socket has been disconnected by the previous owner for some reason so we cannot get any codes to show up on a reader. Another thing I forgot to mention was that the hill start assist isn’t working either. Very strange. I’ve checked to find a fuse for the cruise control and can not find one (I’m new to all this stuff only been driving just over a year) so not sure if there is a fuse for cruise control
Also when I said stop start won’t turn on I meant that the button says off and will not come back on
Batteries only really last their best for 3 or 4 years.  Most never get changed often enough.
Hmm seems we have half a story here. Messing with "a few other things" could've done something, you'd have to ask him. Fuse 63 (10 Amp) in passenger compartment and Fuse 44 (5 Amp) in engine bay for cruise control. Tbh its more likely your mechanic forgot to plug an electrical connector back in, or some of the conductors aren't making good contact. OBD ports are commonly relocated somewhere else hidden in the car to prevent burglars from plugging in their laptop and starting the car without the key. A dummy port is then installed in its place. You'd have to figure out how they've done it and get it working.
Batteries should last for more than 4 years really, if they're looked after. I got one for my Focus the other month that comes with a 5 year warranty!
Ah brilliant! Thanks for your help mate!
  • 5 years later...
The mechanic fitted the wrong master cylinder. there are different ones for start stop. Mine doing the exact same
  • 4 weeks later...
Good day.
Last 2 months noticed that the auto-start stop most times is not activated.
Although the battery is new (November 2023).
Could it be battery again? Charger? Because of the heat (higher than 35C many times higher than 40C)?
Will not operate in high temperature conditions.
Also does not work in August, and never on a Saturday unless it's a leap year. 🤣
https://www.fordownersclub.com/search/?q=Stop start&quick=1&updated_after=any&sortby=relevancy&search_and_or=and&search_in=titles
Because another 1.0 owner complained that during very hot weather it doesn't work so properly.
As I said "Will not operate in high temperature conditions "
The system is designed NOT to work in high temperature conditions.
It's down underneath the battery your power steering fuels another fuses are there as well
5 years to late to the party 🤣
