Durashift
Hello everybody  I bought a 2008 8 Ford Fusion durashift 63000 miles on the clock I'm having trouble with the gear change. it seems to over rev at times before it goes up a gear ,I have been changing it manually but is there an underlying problem this car is only 2 days old to me do I need to return it or am I driving the car wrong somehow. So notice a couple of times when putting it into reverse it doesn't seem to register the gear. again doesn't happen every time , a bit like the other problem sometimes the gears will change ok I'm just wondering whether I anticipate the gear change and take my foot off the accelerator a little bit I have come from a manual car. Thanks in advance for your help if you can
  • 9 months later...
Hi - any tip related to clutch attenuator motor test? And TCM test? But the second issue shall be done by some expert - not me.
TCM and clutch attenuator
Just with key in "II" position and changing D/N/R positions
In the video above the behaviour is OK? E.e. only one Durashift motor does some activity and the other one not?
Thanx for any hint, Pavel
