2016 2.0TDCI - Struggles to immediately after shutting off
Hi all,
I picked this Galaxy up on the weekend from a dealership in Bradford, after initially having my collection delayed as there was no coolant in the vehicle, they replaced the thermostat housing and gasket, touch wood there has been no further drop in coolant.
What I have noticed is, when you switch the car off and try immediately switch it back on, it'll either cut out straight away or try to crank at least 8-10 times shaking before it'll start back up.
This can be demonstrated with the power button, however generally is a massive problem when it comes to stop/start, as you can imagine trying to crank 10 times at a set of lights when it goes green is a massive issue.
I've took a video using the power button
 https://youtu.be/py20yFAFQyk
Any ideas, common issues etc? Absolutely ZERO on the net about it when I've searched.
