Tyre wear
Noticed today both my front tyres have a lot of wear on the outer edges, I've googled it and the common solution is wheel alignment, however, I had my wheels checked at the garage about 7 months ago and they are perfectly aligned, any idea what else it could be?
Tyre pressure perhaps,
Ive had a ford dealer involve my bill for tracking alignment even though they don't have any equipment on site for carrying out alignment,
It usually costs around half the price of a tyre and will save you money on both tyres and fuel economy,
If you drive on country roads alot this can also put the alignment off; have you received any documentation from the garage to show the alignment figures?
Most tracking alignment systems provide a print out for the customer.
I should also mention that when I'm going around sharp corners and roundabouts there is a noticeable rubber sounding 'rubbing' coming from the tyres/suspension area (both sides)
Thats quite a significant addition of information there: the rubbing sound I'd most likely the tyres rubbing the arches? That would wear them down significantly on the outer edges in a matter of weeks,
Are the wheels the correct fitment for the vehicle and has the vehicle been lowered atall?
If you can; have a look around the spring and shock on both sides: look for signs of liquid as this would indicate the shock seals have deteriorated as result; there not dampening the lateral force when cornering etc.
When both shocks are equally deteriorated; the vehicle will still pass an inspection because there wont be any imbalance,
Worn bushes on the lower arm, could be a problem, as could a broken spring (or two).  Another simple check is to look at the track rods, and that both sides are the same length
