Anyone Re-furbed Vignale Wheels?
Looking at having a full size spare and been offered a wheel in need of re-furb - as it's polished alloy rather than painted I wondered if anyone here has managed to re-polish this type of Vignale wheel?
OR anyone got any advice on how best to do it?
No Idea but are you sure it will fir in the wheel well? I looked in to having a full size 19" wheel as a spare on my MK4.5 Mondeo and it does not fit in the well.
Sorry should have made my position clearer - I was thinking that in the event I had to use the 'space saver wheel' I thought it would be useful to have a "spare" full size wheel that I could put on the car to replace the tempiorary wheel whilst the original was being repaired.
i know it would not fit in the wheel well so would be kept in the garage until needed
Having owned cars with low profile tyres before I would rather be ready for it happening :whistling:
  • 1 month later...
In case anyone else is looking for the same help here is a very good video I found on how to repair and polish mag alloy wheels
Searching for a suitable 'spare' wheel I came across a full set of 20" Vignale Rims for less than the price of one - well chuffed :yahoo:
They need some light re-furbishment which I will do in the next few weeks - then add a set of TPMS valves and some winter tyres and I will be well set for the seasons ahead - will post pics if I remember to take them as I go along
Great result, winter tyres are the way forward the brakeing distance in the cold and wet is dramatically reduced allways catchs me out when i first swop. Never mind snow conditions
  • 1 month later...
Update:
Finished stripping the wheels of lacquer and sanding down the metal worm
Just need a couple more dry days to do the final 600 grade rub down and re-polish, then apply 2K lacquer to finish
Here's a few pics of work in progress
Before:
Rot spots taken out with flappy wheel on Dremel (lacquer still to strip):
1st sanding without lacquer 320 grade:
Update:
Fine sanding underway with 1000 grit paper - tried a quick test polish on one section today - well pleased with results using Mothers Mag/Aluminium polish 74565399_2353368208124301_6533577694615961600_n.jpg?_nc_cat=100&_nc_oc=AQk9ooXgefWtpUgXequ9PRbGt91cDHK954aX043otb1tQZ4zywAbY3EB5oeeG-1NgAQ&_nc_ht=scontent-lht6-1.xx&oh=cfbebd4f387ba23ca8c19a112aaa956c&oe=5E18219E
