Speaker Size
Hello,
Anyone here upgrade factory sound, perhaps know the size of the back speakers? Around 6.5"?
Thanks!
11 hours ago, Zee_3 said:
Hello,
Thanks!
Ive upgrade my entire sound system to aftermarket
The best way to find out is on Ebay as you will need model specific to aftermarket speaker adapters,
I don't know what model you have but I searched for "mk2 focus aftermarket speaker adapters" which fills the factory hole then provides a 6.5" hole for an aftermarket speaker,
Search your model on Ebay for aftermarket speaker adapters; there different shape for front and rear doors,
Then see what size of speaker the aftermarket adapter takes as that's then the size you will need.
Hey!
*****, I should've mentioned I have a fiesta MK 7.
But thank you, this does help however!
2 minutes ago, Zee_3 said:
Hey!
Probably the same size. Something to point out some speaker listings say 16cm whereas some say 17cm.
3 minutes ago, zain611 said:
I think it's 17cm.
Heres an ebay ad of some front focal speakers which says for a mk6 fiesta. I think focal are the best in the game.
https://www.ebay.co.uk/itm/Ford-Fiesta-2001-2008-Focal-17cm-Front-Door-Speaker-Upgrade-Kit-/172228731576
Hey,
I see those are front. I have my fronts upgraded already with a split system. Upgrading the back this week.
So just needed to confirm the back size.
Mark 7 is same front and rear:
http://www.caraudiodirect.co.uk/ct25fd10-ford-speaker-adaptors
I used these adapters on my fronts but they listed for rear too
Good to know! Thank you!!
12 minutes ago, ThaiFiesta said:
I've just had all my wires spliced instead, in order to retain factory speakers when/if ever needed.
