Ford Fiesta Mk6 A/C high pressure sensor wiring
Hi All, I've got a 2003 Ford Fiesta 1.4 TDCi thats had a non working air con since I bought it last November. I decided to finally look into it and I've found that the 4 wires connected to the high pressure sensor are split. Whoever owned this car before me had already had a go at repairing this but has done an awful job of it, the actual socket which plugs into the sensor has had the wires completely pulled out of it. I've cleaned up the 4 wires coming from the loom and exposed copper on each of them ready to repair it, however, I'm unsure of which hole each wire goes into to make sure it's connected to the right pin on the sensor, if there had been some cable left coming from the socket I could've matched the colours and easily spliced them back together but I'm unable to do this. The 4 wires each have their own colour, one has a red stripe, one has an orange stripe, one has a green stripe and the other is just black. I'm assuming that these wires are coloured the same on all fiestas from around this year so would it be possible for anyone to show me a photo of theirs so I'm able to put the wires in the right place and repair mine.
Thanks In Advance!
  • 8 months later...
Hi Liam was just wondering whether you ever got wiring colours for ac pressure sensor I have the same issue
thanks Ian
  • 1 year later...
thanks Ian
Hi Ian,
Sorry for the very late reply to this, unfortunately I never found out what each wire was for and my car ended up breaking and is still currently sat as a non runner as I’ve not had time to work on it, I ended up buying a 2009 Focus estate and that’s now my daily. If you’ve still got the problem and I ever find out I’ll be sure to let you know!
