Dashcam Fuse Choices for mk8 fiesta
Hi, got a Garmin 55+ fitted 2 days ago at Halford also the parking mode cable to go with it . Dashcam works ok while driving, parking mode I'm not so sure about.
I believe although the parking mode enables itself when ignition is switched off and key removed it's actually just working from the dash am internal battery as I only get approx 5 hours of use from parking mode. It is not for lack of movement being detected, buses running past 24/7.
I had a look at the fuse box, hardwire kit fusetap goes to fuse number 17 which according to the handbook is voice control,info & entertainment & cd player, fair enough as these come on with ignition.
The parking mode cable is connected to fuse number 3 which handbook says is for parking assist control module, my car does NOT have this module. Would I be correct in saying there may not be anything on the engine side of fuse number 3? Hence parking mode running from internal battery.
Fuse number 5 lock/unlock might have been a better choice... I think.
The issue may lie in that position 3 is a switched live, so turns off when the key turns off as this is the one I use so the camera turns off when I turn off the car.
You may find that switching the two around fixes the problem so long as the car doesn't turn off position 17 after a certain amount of time or something like that.
I know the radio in my old car used to switch off after about an hour, I suspect the mk8 might be the same therefor no use for parking mode. The infotainment screen switches off with ignition. If your cam on fuse No 3 switches off with ignition then I have a valid reason to go back a third time. I'm thinking fuse No 5 lock/unlock maybe a better choice, I'm sure that would be a permanent live ...I think.
My camera is hardwired the same as Daggerit.  Parking assist.  It turns off and on with ignition.
Hope you get it sorted.
