Ford Focus, 1.6l petrol, manual, 2010 cambelt
Hi
Is the water pump driven by the cambelt? The garage put a new cambelt kit on but no water pump as they said it wasn't needed.
Thank you
 It’s driven off the aux belt.
most of the belts I’ve done on these engines the customer usually opts to leave the pump. Not had any pump failures yet.
On 9/4/2019 at 3:57 PM, Cat78 said:
Hi
Thank you
As stef said, I was advised by both the garage I used for servicing and the main Ford dealer to avoid replacing the water pump if it wasn't showing signs of leaking or wear. I left mine when I did my belt.
