Spacesaver
Does anyone know if a 175/65R14 Spacesaver from a ‘13 Plate will fit a ‘19 Plate?
Current wheel dimensions are 205/45R17
Providing the stud pattern is the same  it should physically fit BUT the spare would have a much smaller rolling radius than the normal wheels -16.6mm
Your speedo will also be affected
and it will result in an uneven ride possibly affecting electronic monitoring, GPS and handling
Here's what the calculator on https://www.willtheyfit.com/ says:
Quote
EXISTING                 NEW
Diameter
616.3mm                    583.1mm
Circumference
1936.2mm                 1831.9mm
Speedo error
0%                             5.69%
Reading at 30mph
30mph                       31.71mph
Reading at 60mph
60mph                       63.42mph
Ride height gain
0mm                          -16.6mm
Arch gap loss
0mm                           -16.6mm
Provided the stud pattern is the same yes it will fit, just remember  that spacesavers are just a get you to a place where you can get a repair done, not for general driving and the speed limit of the saver needs to be adhered to. Also note the size is a universal fit thats  a compromise.
