reverse gear hard to engage
Hi, I got a 05 Fusion 1.6, reverse gear is usually tricky to engage. sometimes I have to move it to 1st and then into reverse. all other gears are absolutely fine and pulls well. I had clutch replaced as needed it and this didn't resolve the issue. I heard this issue is common with ford's but unsure what this problem is. anyone had a similar issue that could help.  thanks
  • 6 months later...
My reverse is exactly the same....i looked at the manual and it says this:
Do not engage reverse gear
when the vehicle is moving. This
can cause damage to the
transmission.
Note: Fully depress the clutch pedal
and wait for three seconds before
you select reverse gear.
I've tried this 3 second rule and it engages fine each time.
Could it be....the gear cables that connect the gearstick to the gearbox either not adjusted or stretched a little and needing re adjusted.
I have read this too chris, doesn't a rubber grommet wear too on the ball pin or something ?
 a pic of the linkage assembly below.
94111045_10220910424684445_3159242333640196096_n.jpg.3cd4fb71e6676b212604a7437bfad09f.jpg
Hi Trevor,
Yeah that sounds about right too.
Maybe have a good poke about at both gearbox and gear selector ends of those cables.
