Flat battery 2x
I have had to change my Ford battery twice in a year. Original was the Ford battery which gradually went low. My car has a black box still connected but not active but both batteries went totally flat.
I have taken it to the garage and the alternator is fine.
I do about 100 miles a month, average 12 miles per journey.
Any idea what It could be. Many thanks
Not enough use springs to mind, maybe an intelligent trickle charger is the answer
It has been known for black (telematic) boxes to draw power continuously and kill batteries.
If it's now defunct then pull the fuse(s) and see how you go.
They usually have two fuse taps in place in order to ensure a permanent and ignition live supply attached to the cabin fusebox (under dash on passengers side) and generally an in-line fuse which could well be the easiest to access and pull.
