Focus 2011 mk3 titanium Sony Radio Dead
I have a Focus 2011 Titanium with a Sony radio, it powered off while driving on Friday and I have had a black screen of death since.
I have done the following troubleshooting;
- Checked Fuses, 15, 67 and 79 are working.
- Disconnected battery for 10 minutes.
- Removed the radio and reseated cables.
I assume it's dead and needs to be replaced. The door locks and hazard button work but I get no lights on the radio LCD or facia. What would I need to determine if its power related or the radio?
Also the USB charging port still works in the glovebox, i think this feeds off the same connection?
The hazard and lock button is a different wiring loom I think.
It sounds odd that the whole system has gone down and would suggest a fuse or main supply issue
Are you able to insert a cd into the slot at all and have the radio accept it?
We had this on ours a couple of years ago and it turned out to be a knackered information lcd colour screen. Do a quick search on here or google it and you can quite easily get the trim surround off around the radio and centre air vents which will let you get a part number from the rear of the screen and the hunt for a replacement can start.
It doesnt take CD's, I hear no noises coming from either the LCD or Radio. Seems to be a power issue. Fuses are ok swapped these out just as a test too.
Going to get a multimeter and see if power is going through.
Thanks for this I'll take it out tonight and see what I can get.
  • 2 years later...
Hi my ford focus 2011 titanium Sony music system looks like got locked. It accepts and ejects the CD shows time and date but locked onto 20111 August calendar. Also I am able to change the time on the screen but music is not Turing on the screen.. rest everything seems working fine..
