Fiesta mk7 (2014) Climate Control Blower Not Working
Hi, I have a 2014 Fiesta with climate control and whilst all vent controls and temperature control works fine, the blower motor does nothing.  The blower speed control dial shows it changing speed but there is no air blowing out of any vents regardless of setting.  I have changed fuse 4 in the engine bay and tried swapping the blower motor relay with the cooling fan relay and still nothing. Not really sure where to go next ?
  • 2 months later...
I'm in exactly the same boat. Car hasn't been driven since before Christmas. Checked Fuse 4 and Relay 13 with a multimeter. Did you manage to get yours fixed?
If your shore its not the Fan Resistor then it may the divert flap...This directs the air to where you select it.
This regularly breaks as well.
https://www.ebay.co.uk/itm/123863209867
Hi ive got a fiesta 2012 with the same problem the fan doesn't seem to work ive checked the fuse and relay also changed the fan resistor but still no luck  can any one help  thanks
  • 11 months later...
This just happened to our 2015 Fiesta Ecoboost 125. It is the Titanium model which comes with climate control. There is literally no fan at all, the knobs all seem to do what you would expect but it is 100% silent. We just checked the fuse and that was OK, any recommendations on what to check next?
The post above mentions swapping the  "blower motor relay with the cooling fan relay" is that the next step?
  • 1 year later...
Have you guys figured anything out this just happened on my 2015 fiesta ST
  • 1 year later...
I wonder if anyone here ever diagnosed the issue with this. I'm here because just like ninjagaiden my 2014 Fiesta hadn't moved since before Christmas, driven today for the first time since 22/12 and nothing from the climate controls. Very strange that we've had exactly the same issue after the car has been left undriven for a while...
