TPMS learning
Hi
I have a Ford Focus 2019. I want to program the tpms sensors after switching to Winther tyres.
I found this guide, but I can't get it to work... does anybody know if it should work with the 2019 model or should I get the learning tool?
1) Make sure your tires are inflated to the recommended psi. Mine is 40psi.
2) Turn ignition to the on position. If you have a push button start, push the start button without pressing the brake pedal.
3) Push the hazard light button 6 times. The horn should honk and you should see "Train left front tire" in the LCD display between the tach and speedo.
4) Release air pressure in the front left tire until you hear the horn honk. The LCD display should now read "Train right front tire".
5) Release air pressure in the right front tire until you hear the horn honk.
6) Repeat for the the right rear tire, and then the left rear tire.
7) You should now see "Training Complete" in the LCD display.
8) Fill your tires back up to the recommended pressure.
Get a cheap learning tool off eBay. About £7
You will need to get an activation/learning tool.
Normally on Fords to activate the TPMS training is as follows:
With ignition off...
Press brake pedal once
ignition on
ignition off
ignition on
ignition off
ignition on
press brake pedal once
ignition off
ignition on
ignition off
ignition on
ignition off
ignition on
The horn should sound and “train left front tyre” should be shown on the cluster.
Use your TPMS tool to go around training your TPMS sensors. Front left, then front right, then rear right, then rear left. The horn should sound after each sensor has learned successfully. When finished “training complete” shows on the cluster.
