Ford Fiesta 2014 - Dashboard rattling on startup
Hello everyone.
I bought a japanese  Ford Fiesta 2014 1.0 Ecoboost Automatic from a local dealer. I’ve done a full service at Ford and the car had no problems whatsoever. It currently has 74000km on it.
For about 2 months whenever I start up the engine (keyless start) I can hear some rattling through the dashboard as if something is stuck and can’t move. The rattling seems to appear everytime I change the direction of the airflow.
I’m kinda lost as to what the issue is and was wondering if anyone faced a similar issue and found a solution.
cheers
3 hours ago, Cons_7 said:
Hello everyone.
I bought a Japanese  Ford Fiesta 2014 1.0 Eco boost Automatic from a local dealer. I’ve done a full service at Ford and the car had no problems whatsoever. It currently has 74000km on it.
For about 2 months whenever I start up the engine (keyless start) I can hear some rattling through the dashboard as if something is stuck and can’t move. The rattling seems to appear every time I change the direction of the airflow.
cheers
Hi its most probably blend door actuator gear broken.Loads on you tube about it.look here.
https://www.google.co.uk/search?sxsrf=ACYBGNSgznmmyWYmyr7uZBkgC1cb-bxdzw%3A1577459010657&source=hp&ei=Qh0GXrnqJYGAjLsPr6C0oAw&q=fiesta+heater+motor+gear+broken%2Cclicking&oq=fiesta+heater+motor+gear+broken%2Cclicking&gs_l=psy-ab.3...1219.12486..12696...1.0..0.236.3798.27j12j1......0....1..gws-wiz.......35i39j0i131i67j0i67j0i131j0j0i10j0i20i263j0i22i30j33i22i29i30j33i160j33i21._UbTPzmewsE&ved=0ahUKEwi5k-ffjNbmAhUBAGMBHS8QDcQQ4dUDCAc&uact=5
