ETIS requests
Hello,
In the past, i used the ETIS summary page to view what factory equipment was on my fords.  Since coming back to Ford this month, i know see the ETIS information is reduced without logging in. It looks, to me, that you cant just create a username and you need to be ford approved.
Is there anyone with full ETIS access on this channel, who will do requests for the ETIS vehicle summary information and let me have a copy & paste of it?  I would like to know what was factory fitted and anything else that shows up.
I registered as an independent operator when they restricted what you saw without logging in. I think all I had to give is name and email address. No payment details or anything. It looks to me like everyone can do this unless it’s been altered again recently
As above.
When I login to ETIS I used to be able to get the extended list of Minor features items. Not any more. Clicking the Minor features button does nothing. Has not done for a couple of months or so.
Try a different browser. This happened to me a while ago using Firefox, so I use Chrome when going to ETIS now.
I can no longer get into ETIS at all.   Found this:
I get told to buy stuff. [emoji848]
Sent from my I3113 using Tapatalk
mine still seems to work OK if I log in.
showing minor features like:
Minor Features
  •  Less Roof Line Conversion
  •  Less Rear Mudflaps
  •  Less Front Door Sill Protection
  •  With Glovebox Illumination
  •  Accessory Media Hub 1XUSB
  •  Less Interior Pack
  •  Less Front Mudflaps
  •  With Hill Launch Assist
  •  Brake System - Regenerative
  •  My Key
  •  Less Bulkhead
  •  Tailgate - Powered Upper
  •  Less Tie Down Hooks
  •  Niehl Plant Built
  •  Less Special Equipment Package
  •  Less Exterior Dress Up Package
  •  Less Marketing Flex Prep Pack
  •  Less Sales Badge
  •  Less Special Order Paint
  •  Less SVO Application/Label
  •  Less Exterior Appearance Pack
  •  Marketing Level 1
  •  Less Dress Up RSO
  •  (-) SVP
  •  Less SIP
  •  Less Paint Package
  •  Less Carline Badges
  •  Less Cooling Pack
  •  For Normal Temperature Zones
  •  Less Tyre Repair Service Kit
  •  With Rear Package Tray
  •  Less Global/Auto Closing
  •  Power Front Windows One Touch Up/Do
  •  With Manual Rear Windows
  •  With Light Tint/Dark Tinted Glass
  •  Standard Green Glass Windscreen
  •  With Heated Windscreen
  •  Less Temp Controlled Glove Box
  •  Low Line Cubby Box
  •  Int Environment Clr-Charcoal Black
  •  Int Feat Colour - Charcoal Black
  •  Less Front Floor Mats
  •  Less Rear Floor Mats
  •  With Full Headlining - Moulded
  •  Drivers Visor Mir/Flap/Tick Pocket
  •  SunVisor-Pass/Mir/Flap/Tic Pocket
  •  With Cloth Door Trim Panel Insert
  •  Less Rear Seat Ash Tray
  •  Less Rear Interior Assist Handle
  •  Less Load Rest
  •  Less Load Area Cover
  •  With Load Floor Carpet
  •  First Aid Retain Strap
  •  With W/Triangle. Retainer Straps
  •  Less Exterior Rocker Panel Moulding
  •  Less Exterior Door Frame Mouldings
  •  Less Rear Window Protector
  •  With Rear Spoiler
  •  With Dipping Rear View Mirror
  •  Dual Power Htd Signal Mirrors
  •  With Body Coloured Exterior Mirror
  •  With Driver Seat Back Map Pocket
  •  Passenger Seat Back Map Pocket
  •  With Front 2 Way Headrest
  •  With Fixed Rear Seat Cushion
  •  With Split Fold-Down Rear Seat
  •  With 2 Way Adjustable Rear Headrest
  •  Less Rear Centre Headrest
  •  Seat Back Material-Carpeted
  •  Less Driver Seat Lumbar Support
  •  Less Temp Control Driver Seat
  •  Less Temp Control Passengers Seat
  •  With Drvr/Passngr Seat Belt Minder
  •  With 2nd Row Folding Seat
  •  With Driver 4 Way Mnl.Seat Adjuster
  •  With Pass 2 Way Manual Seat Adjust
  •  Less Trailer Coupling
  •  Less Fuel Economy Pack
  •  Body Coloured Exterior Door Handle
  •  Body Coloured Tailgate Handle
  •  Mld Gear Shift Knob - Black Insert
  •  Soft Feel Gear Shift Boot
  •  With Door Dead Locks
  •  Door Entry R/Cont Unit-2 Flip Keys
  •  Less Keyless Entry System
  •  With Trans Linked Rr Washer/Wiper
  •  V/Intermittent With Anti-Drip Wipe
  •  Less Heated Washer Jet
  •  With Body Coloured Roof
  •  Less U/Body Corrosion Protect
  •  Fr Bumper - Body Colour Lwr Accent
  •  Less Front Bumper Extension
  •  Rear Bumper-Body Colour/Lwr Accent
  •  Rear Bumper Beam
  •  Belt D & P Fr 1 & 2 Row/D Kne Bag
  •  Air Curtain Restraint LH
  •  Air Curtain Restraint RH
  •  Inflatable Knee Bolsters - Driver
  •  Retractable Rear Seat Belt-3Point
  •  With Driver Air Bag
  •  With Passenger Air Bag
  •  With Side Air Bag - Drivers Side
  •  With Side Air Bag - Passenger Side
  •  With Passenger Air Bag Deactivation
  •  With Isofix Hard Point Attachment
  •  With Manual Adjust Frt.S.Belt Mount
  •  Style 1 Tether Anchorage Restraint
  •  Seat Belt Pretensioners Drv/Pass
  •  With Steel Spare Wheel
  •  Tyre Pressure Sensors - 433 MHZ
  •  5 1/2J x 14 Semi-Styled Steel Wheel
  •  175/65R14-H Low Roll Resistance
  •  With Standard Tyre Tread - Front
  •  With Standard Tyre Tread - Rear
  •  Any Brand Tyre Vendor
  •  14" Progressive Wheel Cover-Style E
  •  Less Hub Covers
  •  Non Locking Lug Nuts
  •  Components Unique For Steel Wheels
  •  Less MPH Engine Governor
  •  Cold Start -25 Deg C
  •  Starter - Stop/Start System
  •  Euro 6 Emissions
  •  With Soft Ride Suspension
  •  With Front Stabilizer Bar
  •  Less Exhaust Pipe Extension
  •  With Plastic Moulded H/Brake Grip
  •  With Mechanical Parking Brake
  •  With Front Disc-Brake/Rr Drum Brake
  •  With Non Painted Brake Calipers
  •  Less Low Speed Safety System
  •  Brakes-HLA/ESP/TC/ABS
  •  3.58/1.92/1.20/.87/.68/3.61
  •  Standard Front Seat
  •  With Pollen Filter
  •  With Recirculating Heater
  •  With Diesel Fuel Capability
  •  Fuel Tank Fill Neck-With Inhibiter
  •  Standard Foot Pedal Pad Design
  •  With Electric Power Steering
  •  With Manual Tilt/Slide Stg Column
  •  With Polyurethane (Hard) Wheel
  •  Less Heated Steering Wheel
  •  Less Speed Control
  •  Less Auxiliary Heater
  •  High Series Analog Cluster
  •  With MPH/KMH Speedometer
  •  With Trip Computer
  •  Dual Note Electric Horn
  •  Tyre Inflation Monitor Lvl II
  •  Less Outside Temp Thermometer
  •  MFD Nav Low TFT Screen
  •  Less Navigation System
  •  Navigation Data - Western Europe
  •  Emergency Assistance
  •  Less Revers Gear Alarm
  •  Less Speed Audible Warning Device
  •  With Perimeter Anti-Theft
  •  With Engine Immobilizer - Integral
  •  Less Rear Parking Aid
  •  Less Front Parking Aid
  •  Standard Duty Battery
  •  With A/V Jack
  •  Less Bluetooth
  •  ICE-Mid Aud(1C) With Cnectv + DAB
  •  Ice Feature Pack 6
  •  ICP Nav
  •  4 Speakers Front / 2 Speakers Rear
  •  With Media Gateway Module
  •  Less Voice Activated Modules
  •  With Steering Wheel Radio Controls
  •  Less Smokers Package
  •  Less Cigar Lighter
  •  With Power Point Plug
  •  Less Camera
  •  Less Pwrpoint Plug-Load Compartment
  •  With Level 2 Headlamps
  •  DTRL Lamp Lit In Pos 0 And Pos
  •  Less Front Fog Lamps
  •  Less Cornering Lamp
  •  Less Lighting Packages
  •  Less Interior Light Group
  •  Less Footwell Lights
  •  With Header Courtesy Light
  •  With Courtesy Light Delay
  •  With Rear Overhead Courtesy Lamp
  •  With Load Compartment Lamp
  •  Tail lamps - LED Rear
  •  With High Mounted Stop Lamp
  •  Less Puddle Lamps
  •  With Front Headlamp Levelling
  •  With Conventional Headlamp Control
Still works for me using Google Chrome.
Tried Firefox, Chrome & Microsoft Edge and still can't get Minor Features
Just logged in using chrome and mine is fine too.
Did you re-register as an independent when Ford sent out the email back in September 2019?
Pretty sure I did but will have a go at reregitering as an independant just incase.
Thanks for all the suggestions and replies.
None of my previous accounts allow me to get in without being presented with either heavy worded legal speak or requiring some kind of ford authorisation.
A bit of a pain, just to see the list of factory fitted extras.
