Won’t start
Hi, I bought a fiesta style 2006 1.2 petrol for my daughter who just passed test, the problem is that the engine turns but won’t start, it’s starting on a run, the battery fine, but when I turn off and come back 10 minutes later same thing, engine turning but not starting. ( it’s as if it’s not picking up fuel to start engine).  Please help.
Tom.
Tom.
Check under the bonnet fuse box. Check for loose wires,bad ground ,wriggle relays and wires around etc.Sounds like a loose wire that's not priming the fuel pump.Also check there's a good earth to the engine management solenoid .
Thanks for the quick reply. 👍🏻
Your welcome i just hope it works for you.
