Help needed
Evening guys
So I am having some issues with the water system
I think it may be an air lock
I fill up the tank and get the car running, after some time the water level drops
I fill it back up and the process starts again
This happens over and over
There is no sign of a head gasket failure
No oil / water mix
The water pump sounds ok
I have changed the thermostat
Any ideas
check all the hoses they maybe a pin hole in them and you can lose a lot of water from them when running😟
How far does the level drop?   It might be finding its natural level.
The header tank is almost empty
Im not sure if it's an air lock
Was 1 topic not enough? Lol
You may find it is still settling down.May take a little while,as long as you did the basics fill slowly , making sure highest point had coolant in it.Start car heater on , full blast , hot and on screen setting you should be okay...You can also run it stationary with the expansion cap of and see if any bubbles start a popping ie air then level would drop to replace this obviously.
If not look for a leak when up to running temp ie under pressure,rad,pipes etc thats when you will see a leak.Oh check carpet is not wet in case leaking from the matrix.
I had the same fault and it was the thermostat sticking
