Help needed
Need some help and advise
i have a Ford Fiesta 2013 Zetec. The header tank has started bubbling and leaking when the car gets hot and has been stood for a moment of time on tick over
I have checked the head gasket and the pressure and all seem ok
am thinking thermostat could be sticking
Def sounds like a stuck thermo,if the head gasket is sound,but the head gasket can also break into the coolant system from combustion, can you see any white smoke out of the exhaust ? if you can have a sniff and put hand near exhaust and see if it feels sort of slippery shiny,this will indicate coolant burning in the combustion chamber.
I would go with thermostat
is the electric fan on the radiator running? do you have a temperature guage on the dash? what does it say?  I think facelift (mk7.5) has gauge but mk7 pre facelift does not.
