Fiesta climate control
Hi, having an issue with my climate control the last couple of weeks it has only blown really hot air out of the fans Bar a random 30 second blast of cool air every 20 minutes unless it’s in Lo in which case I only get cold air blown out. Am thinking it’s the unit itself rather than any actuators any ideas? Coolant level is also fine
Check coolant level,if thats okay then check coolant control valve (bulk head if you have one) if not then maybe the blend door actuator.
