Ford Fiesta Style Plus dashboard lights
Hi Ford owners club, I own a Ford Fiesta 2009 style plus had it for over 2 years now and long story short my fuse for the cigar lighter had blown so I used another of the same fuse and placed it in the correct fuse and now working fine. The query is, the one I took out stopped lighting up when I started the car then most of them turn off as they should do. However, as you can see from the picture many of them do not light up when the initial start of the ignition is applied. 1. First question, should all symbols on the dashboard light up before fully start up? 2. Or do the ones that have not light up fuses/relays have blown? I hope someone would be so kind as to advise me on an answer. Much appreciated, Jake.
84340029_2790856857660836_1756053312328695808_n.jpg?_nc_cat=103&_nc_ohc=iWjrmj1L-GwAX86pX0-&_nc_ht=scontent-lht6-1.xx&oh=ffb30302220b63b41f3d8f8f7a7e1392&oe=5ED076F9
Will only light up what you have fitted ie no glow coil because your petrol , some will light when in use only as well..
