Long beeping sound after turning the ignition on
Every time after I want to turn on my car (Ford fiesta 1.6 tdi 2014) this strange beeping occurs.
I went to plenty garages, no one noes what is it.
Anyone?
https://youtu.be/wzXbSNtaotc
Did the car eveh have a black box telematics kit or hands free phone module fitted?
Sounds aftermarket to me for sure.
Usually that sort of sound is because some bits have been removed but the main control module is still attached somewhere and is giving a fault alarm.
I have this car only two weeks and it's like this since then.
Unfortunately I have no knowledge of if anything was fitted in.
But this car has originally bluetooth bild in so maybe it's telematics...
How can I check this?
Have a look at the footwell fusebox snd if you see any fusetaps then it's likely there was a telematics fitted.
They are usually plumbed into two fuse locations so pulling the taps out and putting the lower fuse back into the fuseboard slot will disable the unit totally.
The obd data port tends to have a patch connector fitted as well so the system can access car data so you will need to pull the socket out and trace back & unplug the patch connector then tefit the original port into it's mount.
Of course this is only relevant if your car DID HAVE telematics installed.
Correct youtube link! :)
Thank you, i will give it a try
