No reverse lights on my 03 MK6 Fiesta LX 1242cc
Changed fuse and bulb, no dice.
Where would I find this switch I've been told about?
Thanks in advance for the help.
On the gearbox, I'm guessing,  as it it on the Mondeo mk3
not 100% certain but I reckon it's on front of gearbox. if you stick you head under front bumper and look at front of gearbox it should be there. when I had same problem on my focus mk1 it just needed the plug on the switch prodding a bit and reverse light came back to life. Once I found that was where the problem lay I unplugged it and put some wd40 and pushed the connector on and off a few times.  it was fine after that.
Of course it's nice to have the light working but on a car of that age it's not part of the mot test (it is on newer cars)
Thank you so much for the help, I have since located it and will work on it when I can get into my bonnet.
