Engine removal
Hello. A quick question if I may. I am going to remove the engine from a 2015 1.5 diesel Fiesta ( cambelt failure at 60k ). Does it come out up, down or forward and with the gearbox or without? Thank you for your help
Evening, I have just completed an engine swap and I took mine out the front
Was easy
Good luck
Yeah saw an ZetecS in a local garage, thought it had been in a front end smash, alas that wasn't the case....engine was removed as it was shot and so was the clutch.
Yeah easiest way is to take the front end off and remove it that way complete with gearbox, easy enough job.
