Coolant hose urgent question
Hi all,
I have a 64 plate fiesta st180, just been cleaning it and have cracked the cooling tank overflow hose, the top one.
I'm looking at replacements but can only see ones for the 1.6 non st version or diesel ones, will any versions fit mine??
What you need to find is the Ford part number for the item, its called the finis code. The way to find it is to go on www.catcar.info and enter your car's vin, then look for the part. Note its finis code, then compare it to the finis code of the ones from the other cars (diesel and non-St)
What I do is once I've got the finis code, I do a search on ebay for 'Ford + finis'  then see the results.
7 hours ago, m11kky said:
Hi all,
I've done the same, got mine from local Ford garage, wasn't that expensive
