Fiesta active, wheel arch covers?
So the active has plastic stuff stuck on the wheel arch covers. Just curious if anyone’s got one and how it is for collecting dirt? Can you remove them to clean beneath?
I live in an area that gets a lot of salt/mud on the roads and I often find trim, nooks, and crannies full of gunk.
Best jack up the relevant side - Then remove the road wheel - Arch liner is held in place by numerous plastic push fit clips, you need a tool to remove the clips - When all the clips are off gently pull the liner away from the body and it'll drop down.
If you haven't a tool you can use a dinner fork but this is the kind of proper tool that is needed.....
Cheers Ian, good to know you can remove them to clean behind, ta
