inside "A" pillar trim
Hi,does anyone know how to remove the trim inside the A pillar(drivers side)so i can get at the screen defrost wires,cheers in anticipation,vic.
Never taken mine off, i would imagine as with most trims with no screws or covers that it will just pop off Vic - just like seatbelt post covers etc ?
If you show me a pic and it's same as mine i will have a look
Start by pulling off the door seal alongside the "A" pillar, then pull the trim away, starting at the top.  Not easy, and you may break a clip or two !
Do we assume that you have a problem with the HFS ?
Hi,yes the wires from the front heated screen are broken and i need to have a look to see if i repair them,thanks for replying vic.
Thanks for your reply Trev i will try to do that,vic.
