Blowing heat air
Hi folks
My mothers Fiesta MK5 JH,JD has a problem. Hot air is blowing through the vents all the time even when blowers are set to blue (cold). What could cause that problem ? faulty heating control panel ?
If a "JH, JD" is the previous version to your 2007, then it could have a problem with the Heater control valve.
I did some googling and probably it will be heating valve as you mentioned I will check it
