08 s max engine malfunction/gearbox service
I’m hoping someone can help, I have an 08 2.0 tdci titanium and a few weeks ago the engine malfunction warning followed by gearbox service required warning came up on the display on the dash followed by the car going into limp mode but if I switched the car off and back on again the fault would reset and drive fine until it does it again,  I had 2 diagnostics done and both said: cooling fan 1 circuit malfunction, turbocharger boost control A limit exceeded and transmission control system malfunction, the person I spoke to after having the second diagnostic done which was done by a gearbox specialist doesn’t believe the gearbox is at fault but something else triggering the gearbox, is it possible if I have a a turbo problem that it could trigger a gearbox and cooling fan fault too?
