Windscreen washer sorted
There was no water coming out of my 67 plate focus windscreen washer managed to get the pump out and the filter was a right mass of sticky slime!! Works a treat now!
Eurgh!
Which screenwash do you use?
This stuff
Wont be using it again😂
I would recommend that even if you use pre-mixed wash fluid, adding a pint of water will thin it down a bit without really reducing the effectiveness but will help to avoid clogging and sludge.
With concentrated wash add an extra pint too, your wash pumps will work far better.
I add some distilled vinegar at times so that any scale is dissolved (also beneficial against salt smearing in winter).
Lol, definitely one to avoid then!
Surprised a Michelin product would do that but I reckon the 'rain shield' is some sort of wax that's separated out and sludged at the bottom.
Could be I only used it really water down too!!
2 hours ago, Stoney871 said:
........I add some distilled vinegar at times so that any scale is dissolved (also beneficial against salt smearing in winter).
If you use distilled water to mix with the screen wash you don't have to ad distilled vinegar
Maybe, but you don't get that "I've had chips" smell [emoji6]
Chips are the last thing I want on the windscreen! :biggrin:
