Door wiring (door ajar wire)
I have a Ford Fiesta 2009 1.4 tdci the door ajar light stays on for the passenger door. The switch in the lock is broken common fault apparently. Is there a wire I can disconnect where the wires run from dash into passenger the door? As there are many wires so one must control the door ajar to tell the car the doors always shut? Because as you know I can’t lock the car because of this reason!! Can’t find the wiring details anywhere! I know there’s many colours as I’ve had a look by taking the rubber cover off and investigated the wires thinking one may be loose but no joy! Thanks for your help
