Roof bars for Fiesta Mk7
Can anyone tell me how to fit roofbars to a Mk7 Fiesta ? Do they fit on the roof gullies ? or inside the doors ?
Genuine ones fit in the gulleys.  Some aftermarket fit in the doors.
Check top of door frame genuine ford bars may fit in the gully and the door, on my S-Max there is a slot in the door frame to ensure in is fitted in the right position
Have you definitely got a Mk7 and not a Mk7.5? I note the 2014 date in your details...
The reason I ask is that at some point Ford dropped the screw-in attachment for roof bars and I'm sure it might've be around the Mk 7 / 7.5 switchover (2013?). I think it was due to the risk of water ingress once the bolt holes had been used. Later models now don't have them and so roof bar attachment is via clamping. I wouldn't want you ripping the roof strips off your car only to find there's nothing underneath them!
For what it's worth I've got a pair of clamp-on Cruz Airo T aluminium bars and have found them excellent. I did consider Thule but they were more expensive, bulkier and have a lower weight rating so didn't see any benefit despite them normally being my go-to brand.
I have a thurl set and I would go for the Cruze set if I was in the market now as they take 60kg over 40kg of the thurl set and are cheaper. The way to look at it is you can carry a light load on a Cruze set but can't carry a heavy load with a thurl set.
