Ford Fiesta Door Microswitch Problem
Hi, my 07 Fiesta 2 doors passenger door randomly says its open when its not.  I believe its the microswitch on the latch but hear its a real pain to change.
Ive heard options on how to trick the car to think the doors closed all the time.  I was wondering how do you achieve this as its a annoying problem!  Or if theres a better option any help would be appreciated.  Thanks
Apparently their built into the door latch assembly but can be unplugged to turn the light off and trick the ecu into thinking that the door is always closed
Would unplugging still require taking apart the door in the same way you would to replace???
Only the door card.
thank you very much, will the central locking still work do you know??
It should do but once of , it should be straight forward to find what wire is the light feed to door open.
